I have two layers : Rivers (as a polyline shapefile) and lakes (as a polygon shapefile).
I want to create a new layer of proximity factor to the streams (Rivers and lakes) which varies by intervals from 5 (near the streams) to 1 (the most distant zones).
I used Merge and Union tools. Also I transformed these layers to Raster and I used Euclidean Distance in ArcGIS 10.2... but these solutions didn't work.
Can you show me which solution is the most appropriate to this study case ?
Thank you in advance
Just I inform you that I tried to combine in a unique raster named Constraints:
- The water raster obtained from rivers and lakes layers (having the value 1).
- Roads raster which has the value 100.
- NonForest raster which has the values 1 and 0 (1 for NonForest pixels and 0 for Forest pixels).
So I used Raster Calculator: [Constraints]=[water] + [Roads]+[NonForest]
The result was incomprehensible raster representing points scattered in space and having the values 101 and 102.
I found the same result when I tried to create the following raster (Raster Calculator): [Soil Loss]=[Factors]-[Constraints].
