haniu_ntt
select by attrib then copy
Discussion created by haniu_ntt on Feb 12, 2014
Latest reply on Feb 16, 2014 by haniu_ntt
dear experts,
i want to select some objects from SDE FC inside a FD then copy them into FileGDB (SELECT BY ATTRIBUTE first, then the result of the select is made as input to subsequent process, which is the COPY).
I built a model and then import the script:
# pyton.py
# Created on: Wed Feb 12 2014 05:31:43 PM
#   (generated by ArcGIS/ModelBuilder)
# Import system modules
import sys, string, os, arcgisscripting
# Create the Geoprocessor object
gp = arcgisscripting.create()
# Load required toolboxes...
gp.AddToolbox("C:/Program Files (x86)/ArcGIS/ArcToolbox/Toolboxes/Data Management Tools.tbx")
# Local variables...
#results to keep the selection
LU_jpna_DJ = "D:\\_hadniu_\\DefaultGDB.gdb\\LU_jpna_DJ"
jpna_opt_SDE_landuse_DJ = "jpna_opt.SDE.landuse_DJ"
#SDE FC in a dataset
jpna_opt_SDE_landuse_DJ__2_ = "jpna_opt.SDE.landuse_DJ"
# Process: Select Layer By Attribute...
gp.SelectLayerByAttribute_management(jpna_opt_SDE_landuse_DJ__2_, "NEW_SELECTION", "OBJECTID < 70")
# Process: Copy Features...
gp.CopyFeatures_management(jpna_opt_SDE_landuse_DJ, LU_jpna_DJ, "", "0", "0", "0")
When i run the script, it gave me error something about parameter in SelectLayerByAttribute_management is not correct.
What could be wrong ? Why the generated script is not correct (one sample is that it cant define the location of the SDE connection) ? What workspace should i set, workspace in file geodb or SDE geodb ?
Please help
thanks
Outcomes
