Solved! Go to Solution.
map.centerAndZoom(geom, 19);
dojo.connect(dom.byId("address"), 'onkeyup', function(event) { if (event.keyCode == 13 && this.value.length > 0) { locate(); } });
Hi Keisuke,
Try adding the following before the locate() function:dojo.connect(dom.byId("address"), 'onkeyup', function(event) { if (event.keyCode == 13 && this.value.length > 0) { locate(); } });
registry.byId("locate").on("click", locate);
on(dom.byId("address"), "keyup", function(event){ if (event.keyCode == 13 && this.value.length > 0) { locate(); } })
It will work after you comment out the following line:registry.byId("locate").on("click", locate);
Also, here is an update to the previous code I sent using the new "dojo/on" module if you're interested:on(dom.byId("address"), "keyup", function(event){ if (event.keyCode == 13 && this.value.length > 0) { locate(); } })
You will need to add "dojo/on" and "on" to require and function.
<input type="text" id="address" value="380 New York St, Redlands" size="30"/>
I would recommend creating a text input rather than textarea:<input type="text" id="address" value="380 New York St, Redlands" size="30"/>
if (candidate.score > 80) { console.log(candidate.score); var attributes = { address: candidate.address, score: candidate.score, locatorName: candidate.attributes.Loc_name }; geom = candidate.location; var graphic = new Graphic(geom, symbol, attributes, infoTemplate); //add a graphic to the map at the geocoded location map.graphics.add(graphic); //add a text symbol to the map listing the location of the matched address. var displayText = candidate.address; var font = new Font( "16pt", Font.STYLE_NORMAL, Font.VARIANT_NORMAL, Font.WEIGHT_BOLD, "Helvetica" ); var textSymbol = new TextSymbol( displayText, font, new Color("#666633") ); textSymbol.setOffset(0,8); map.graphics.add(new Graphic(geom, textSymbol)); return false; //break out of loop after one candidate with score greater than 80 is found. } else{ alert("No results found, please enter another address"); } });
<input type="text" id="address" value="380 New York St, Redlands" size="30" autofocus="autofocus"/>
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10"
<!--The viewport meta tag is used to improve the presentation and behavior
of the samples on iOS devices-->
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
<title>Info Window Lite</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.7/js/esri/css/esri.css">
<style>
html, body, #mapDiv { height: 100%; margin: 0; padding: 0; }
</style>
<script src="http://js.arcgis.com/3.7/"></script>
<script>
require([
"esri/map",
"esri/dijit/InfoWindowLite",
"esri/InfoTemplate",
"esri/layers/FeatureLayer",
"dojo/dom-construct",
"dojo/domReady!"
], function(
Map,
InfoWindowLite,
InfoTemplate,
FeatureLayer,
domConstruct
var map = new Map("mapDiv", {
basemap: "topo",
center: [-98.416, 39.781],
zoom: 6
var infoWindow = new InfoWindowLite(null, domConstruct.create("div", null, null, map.root));
infoWindow.startup();
map.setInfoWindow(infoWindow);
var template = new InfoTemplate();
template.setTitle("<b>${PARCELID}</b>");
template.setContent("${owner1_name} \n ${site_address}");
//add a layer to the map
var featureLayer = new FeatureLayer("http://gis.wiu.edu/arcgis/rest/services/mcdonough_highway/MapServer/21", {
mode: FeatureLayer.MODE_ONDEMAND,
infoTemplate:template,
outFields: ["PARCELID" , "site_address", "owner1_name"]
map.addLayer(featureLayer);
map.infoWindow.resize(200, 75);
</script>
</head>
<body c>
<div id="mapDiv"></div>
</body>
</html>
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Find Address</title> <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } #map{ padding:0; border:solid 1px #343642; margin:5px 5px 5px 0px; } #leftPane{ width:20%; border-top: solid 1px #343642; border-left: solid 1px #343642; border-bottom: solid 1px #343642; margin:5px 0px 5px 5px; color: #343642; font:100% Georgia,"Times New Roman",Times,serif; /*letter-spacing: 0.05em;*/ } </style> <script src="http://js.arcgis.com/3.8/"></script> <script> var map, locator; require([ "esri/map", "esri/tasks/locator", "esri/graphic", "esri/dijit/InfoWindowLite", "esri/InfoTemplate", "esri/layers/FeatureLayer", "dojo/dom-construct", "esri/InfoTemplate", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/Font", "esri/symbols/TextSymbol", "dojo/_base/array", "dojo/_base/Color", "dojo/number", "dojo/parser", "dojo/dom", "dojo/on", "dijit/registry", "dijit/form/Button", "dijit/form/Textarea", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!" ], function( Map, Locator, Graphic, InfoWindowLite, InfoTemplate, FeatureLayer, domConstruct, InfoTemplate, SimpleMarkerSymbol, Font, TextSymbol, arrayUtils, Color, number, parser, dom, on, registry ) { parser.parse(); map = new Map("map", { basemap: "topo", center: [-90.674923, 40.460873], zoom: 17 }); /*var infoWindow = new InfoWindowLite(null, domConstruct.create("div", null, null, map.root)); infoWindow.startup(); map.setInfoWindow(infoWindow);*/ var template = new InfoTemplate(); template.setTitle("<b>${PARCELID}</b>"); template.setContent("${owner1_name} \n ${site_address}"); //add a layer to the map var featureLayer = new FeatureLayer("http://gis.wiu.edu/arcgis/rest/services/mcdonough_highway/MapServer/21", { mode: FeatureLayer.MODE_ONDEMAND, infoTemplate:template, outFields: ["PARCELID" , "site_address", "owner1_name"] }); map.addLayer(featureLayer); map.infoWindow.resize(200, 75); on(dom.byId("address"), "keyup", function(event){ if (event.keyCode == 13 && this.value.length > 0) { locate(); } }) locator = new Locator("http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer"); locator.on("address-to-locations-complete", showResults); // listen for button click then geocode //registry.byId("locate").on("click", locate); map.infoWindow.resize(200,125); function locate() { map.graphics.clear(); var address = { "SingleLine": dom.byId("address").value }; locator.outSpatialReference = map.spatialReference; var options = { address: address, outFields: ["Loc_name"] } locator.addressToLocations(options); } function showResults(evt) { var candidate; var symbol = new SimpleMarkerSymbol(); var infoTemplate = new InfoTemplate( "Location", "Address: ${address}<br />Score: ${score}<br />Source locator: ${locatorName}" ); symbol.setStyle(SimpleMarkerSymbol.STYLE_SQUARE); symbol.setColor(new Color([153,0,51,0.75])); var geom; arrayUtils.every(evt.addresses, function(candidate) { console.log(candidate.score); if (candidate.score > 80) { console.log(candidate.score); var attributes = { address: candidate.address, score: candidate.score, locatorName: candidate.attributes.Loc_name }; geom = candidate.location; var graphic = new Graphic(geom, symbol, attributes, infoTemplate); //add a graphic to the map at the geocoded location map.graphics.add(graphic); //add a text symbol to the map listing the location of the matched address. var displayText = candidate.address; var font = new Font( "16pt", Font.STYLE_NORMAL, Font.VARIANT_NORMAL, Font.WEIGHT_BOLD, "Helvetica" ); var textSymbol = new TextSymbol( displayText, font, new Color("#666633") ); textSymbol.setOffset(0,8); map.graphics.add(new Graphic(geom, textSymbol)); return false; //break out of loop after one candidate with score greater than 80 is found. } else{ alert("No results found, please enter another address"); } }); if ( geom !== undefined ) { map.centerAndZoom(geom, 12); } } }); </script> </head> <body class="claro"> <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'sidebar', gutters:false" style="width:100%; height:100%;"> <div id="leftPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'"> Enter an address then click the locate button to use a sample address locator to return the location for street addresses in the United States. <br> <input type="text" id="address" value="380 New York St, Redlands" size="30" autofocus="autofocus"/> <!--<textarea type="text" id="address">380 New York St, Redlands</textarea>--> <br> <!--<button id="locate" data-dojo-type="dijit/form/Button">Locate</button>--> </div> <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"> </div> </div> </body> </html>
