Hi. I am new to ArcGIS. I opened up ArcMap for visualization and to run analysis on a database. One of the contents of my database folder is an .e00 file. That is, an ArcInfo Workstation export interchange file. I'd like to import this file into ArcMap. So, I opened up a Python window and typed in the following commands. It is an example from ArcGIS 10.2.1 Help. I changed my environment settings to the location of the e00 file and used the same location for my output data. When I ran "arcpy.Import_arc(...)", I got the following error.
AttributeError: Object: Tool or environment <Import_arc> not found
Could you please tell me how to fix this? I opened up arc.py and the file has Import_arc. So, I'm not sure why I am getting the error. Thank you!!
# Name: Import_Example.py
# Description: Imports from E00 format to a coverage
# Requirements: ArcInfo Workstation
# Import system modules
import arcpy
from arcpy import env
# Set environment settings
env.workspace = "C:/data"
# Set local variables
featureType = "COVER"
interchangeFile = "citylim.e00"
outDataset = "C:/output/citylimit"
# Execute Import
arcpy.Import_arc(featureType, interchangeFile, outDataset)
