HandsomePete
Beginner Multiprocessing Question
Discussion created by HandsomePete on Feb 6, 2014
Latest reply on Feb 7, 2014 by HandsomePete
I'm trying to run a really simple multiprocessing script but I get an error that says "AttributeError: 'module' object has no attribute 'f'.  *See script below.  Every time I try to run any sample script w/ a multiprocessing process, I get the same error.  I'm on Windows 7, with the stock Python 2.6 install that comes with ArcMap 10.0.  I also tried this on a machine with 10.1 and Python 2.7 and got the same error.
I got the script from here:
http://docs.python.org/2/library/multiprocessing.html
*The script is:
from multiprocessing import Process
def f(name):
    print 'hello', name
if __name__ == '__main__':
    p = Process(target=f, args=('bob',))
    p.start()
    p.join()
Full error output
FIle "(string)", line 1, in (module)
File "C\Python26\ArcGIS10.0\lib\pickle.p",line 1370, in load
return Unpickler(file).load()
File ""C\Python26\ArcGIS10.0\lib\pickle.p",line 858, in load
dispatch[key](self)
"C\Python26\ArcGIS10.0\lib\pickle.p",line 1090, in load_global
klass = self.find_class(module,name)
"C\Python26\ArcGIS10.0\lib\pickle.p",line 1126, in find_class
klass = getattr(mod,name)
Outcomes
