adrianeesquivel
Putting raster file with big extention in shapefile
Discussion created by adrianeesquivel on Feb 6, 2014
Latest reply on Feb 6, 2014 by xander_bakker
Hello, I have a raster file with huge extention values:
Top 2862682.68853
Left -8067545.46588
Right 17050954.5341
Bottom -2862317.31147
Spatial reference WGS_1984_Mollweide
Liniar Unit Meter 1.00000
Angular Unit Degree (0.017453292519943299)
Datum D_WGS_1984
And I want to fit it in the same projection as a shapefile
Geometry Type: Polygon
Projected Coordinate System: WGS_1984_World_Mercator
Projection: Mercator
False_Easting: 0.00000000
False_Northing: 0.00000000
Central_Meridian: 0.00000000
Standard_Parallel_1: 0.00000000
Linear Unit: Meter
Geographic Coordinate System: GCS_WGS_1984
Datum: D_WGS_1984
Prime Meridian: Greenwich
Angular Unit: Degree
I have been trying to batch in the same projection but nothing really worked. Do you know how can I do that?
Many thanks!
Outcomes
