Hi.I am trying to make an application where one field depends on a value in another field. I have used the field calculator in ArcMap. The idea is to specify a text on behalf of a value. My field calculator looks like this:Dim tykkelse
If [Isens_tykkelse] < 15 Then
tykkelse = "Isen er IKKE sikker"
elseif [Isens_tykkelse] > 15 Then
tykkelse = "Isen er sikker"
else
end if
__esri_field_calculator_splitter__
tykkelse
I have shared the dataset as a service and build an application. Now I would like to edit the data through the collector app. But when I update the value, the text field dosent update due to the field calculator.Any solution ideas?
