require(["esri/map", "esri/geometry/Extent", "esri/dijit/OverviewMap", "esri/dijit/BasemapGallery", "esri/arcgis/utils", "esri/dijit/HomeButton", "esri/layers/ArcGISTiledMapServiceLayer", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/dijit/Legend", "esri/dijit/Popup", "esri/layers/FeatureLayer", "esri/InfoTemplate", "dojo/dom", "dojo/dom-construct", "dojo/dom-class", "dojo/_base/array", "dojo/on", "dojo/parser", "dijit/registry", "dijit/form/CheckBox", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/TitlePane", "dojo/domReady!"], function (Map, Extent, OverviewMap, BasemapGallery, arcgisUtils, HomeButton, ArcGISTiledMapServiceLayer, ArcGISDynamicMapServiceLayer, Legend, Popup, FeatureLayer, InfoTemplate, dom, domConstruct, domClass, arrayUtils, on, parser, registry, CheckBox ){ var map = new Map("mapDiv", { zoom: 3, basemap: "streets", sliderStyle: "large", sliderPosition:"top-right", logo: true, nav:false, navigationMode: 'css-transforms', autoResize: true, }); var dynaLayer1 = new ArcGISDynamicMapServiceLayer ("http://server.arcgisonline.com/arcgis/rest/services/Demographics/USA_Diversity_Index/MapServer", { opacity: 0.8 }); var dynaLayer2 = new ArcGISDynamicMapServiceLayer ("http://server.arcgisonline.com/arcgis/rest/services/Demographics/USA_Median_Age/MapServer", { opacity: 0.8 }); //Add a legend var layerInfo; map.on("layers-add-result", function (evt) { layerInfo = arrayUtils.map(evt.layers, function (layer, index) { return { layer: layer.layer, title: layer.layer.name }; }); if (layerInfo.length > 0) { var legendDijit = new Legend({ map: map, layerInfos: layerInfo }, "legendDiv"); legendDijit.startup(); } }); map.addLayers([dynaLayer1, dynaLayer2]); //Add a checkbox var cb; map.on("layers-add-result", function (results) { array.forEach(layerInfo, function (layer) { var layerName = layer.title; var checkBox = new CheckBox({ name: "checkBox" + layer.layer.id, value: layer.layer.id, checked: layer.layer.visible, onChange: function (evt) { var clayer = map.getLayer(this.value); clayer.setVisibility(!clayer.visible); this.checked = clayer.visible; } }); //checkbox ends }); // forEach ends }); var thinger = domConstruct.toDom("checkBox "); domConstruct.place(thinger, dom.byId("toggle"), "after"); //toggle is the div id to put checkbox
Solved! Go to Solution.
You're using array.forEach in your code, but in the function, you're assigning the alias "arrayUtils" for the array module "dojo/_base/array".
Try using "arrayUtils.forEach" instead. There was a similar question where I replied with a Fiddle that is written in AMD style.
