AnsweredAssumed Answered
Area Solar Radiation from Python script - error
Question asked by todd93 on Jan 29, 2014
Latest reply on Jan 30, 2014 by todd93
I am attempting to execute Area Solar Radiation in a stand-alone python script (shown below). The basis for the script was provided in the ESRI tool help. I made a few adjustments to this template by adjusting a few of the local variables and adding try/except etc.
The problem is that when I execute the script, it runs for about a minute then fails with an ERROR 999999 (also shown below in quoted script output).
Does anyone have an idea on why this may be occurring?
# Name: SolarRad_MayJuly.py # Description: Derives incoming solar radiation from a raster surface.  #              Outputs a global radiation raster and optional direct, diffuse and direct duration rasters #              for a specified time period. (May to July). #               # Requirements: Spatial Analyst Extension  # Import system modules import arcpy, time from arcpy import env from arcpy.sa import *  # Set environment settings env.workspace = "D:/Projects/Tasks/02_SpatialInputs/SolarRad/work/MayJulyOutput"  # Check out the ArcGIS Spatial Analyst extension license arcpy.CheckOutExtension("Spatial")  # Set local variables inRaster = "D:/Projects/Tasks/02_SpatialInputs/Geomorph/ElevationSlope/elev" latitude = 37.1567 skySize = 200 timeConfig = TimeMultipleDays(2012, 121, 212) dayInterval = 14 hourInterval = 1 zFactor = 1 calcDirections = 32 zenithDivisions = 8 azimuthDivisions = 8 diffuseProp = 0.3 transmittivity = 0.5 outDirectRad = "" outDiffuseRad = "" outDirectDur = ""  print time.asctime(time.localtime()) print "Running Area Solar Radiation..." try:     # Execute AreaSolarRadiation     outGlobalRad = AreaSolarRadiation(inRaster, latitude, skySize, timeConfig,        dayInterval, hourInterval, "NOINTERVAL", zFactor, "FROM_DEM",        calcDirections, zenithDivisions, azimuthDivisions, "UNIFORM_SKY",        diffuseProp, transmittivity, outDirectRad, outDiffuseRad, outDirectDur) except:     print "Error while processing solar radiation"     print (arcpy.GetMessages())  # Save the output  outGlobalRad.save("D:/Projects/Tasks/02_SpatialInputs/SolarRad/work/MayJulyOutput/globrad") print "Finished" print time.asctime(time.localtime())
Tue Jan 28 09:52:16 2014
Executing: AreaSolarRadiation D:/Projects/Tasks/02_SpatialInputs/Geomorph/ElevationSlope/elev D:/Projects/Tasks/02_SpatialInputs/SolarRad/work/MayJulyOutput\AreaSol_elev1 37.1567 200 "MultiDays   2012  121  212" 14 1 NOINTERVAL 1 FROM_DEM 32 8 8 UNIFORM_SKY 0.3 0.5 # # #
Start Time: Tue Jan 28 09:52:16 2014
ERROR 999999: Error executing function.
Failed to open raster dataset
Failed to execute (AreaSolarRadiation).
Failed at Tue Jan 28 09:53:33 2014 (Elapsed Time: 1 minutes 17 seconds)
Outcomes
