kdevine321
Help fix tool to which uses a txtbox to make selection. pFeatureSelection broken
Discussion created by kdevine321 on Jan 28, 2014
Latest reply on Jan 30, 2014 by kdevine321
Hello all,
I'm trying to migrate some VBA code written in 9.2 into a Win7, Office 2010, 10.2 format and I'm having a little trouble as I'm very novice at programing.  My tool is pretty basic that I'm trying to create.  It uses a form with a textbox to which someone would paste in text in to be used as a selection. Its basically just a select by attributes with a custom form since all the selections are on the same field in the same layer.  Layer = Forest Field = ID Format is always XX0000-0000.  My tool runs through the code successfully but stops at the pFeatureSelection.SelectFeatures at the bottom below the pActiveView and does not make a selection.  I can't figure out what is going on.  I've tried pasting in what seems like updated code format but it does not like this barks at me.  If anyone has suggestions it would be very appreciated.
Public Sub CommandButton1_Click()
        Dim pStID As String
        Dim pMxDoc As IMxDocument
        Dim pMap As IMap
        Dim pActiveView As IActiveView
        Dim pFeatureLayer As IFeatureLayer
        Dim pFeatureSelection As IFeatureSelection
        Dim pQueryFilter As IQueryFilter
        Dim pEnumLayer As IEnumLayer
        Set pMxDoc = Application.Document
        Set pMap = pMxDoc.FocusMap
        Set pActiveView = pMap
        Set pEnumLayer = pMxDoc.FocusMap.Layers
        Set pFeatureLayer = pEnumLayer.Next
        Do Until pFeatureLayer Is Nothing
        If pFeatureLayer.Name = "Forest" Then
        Exit Do
        End If
        Loop
        'txtID.pActiveSheet.Range("ID").Select
        'txtID.Selection.Copy
        'txtStID.Paste
        'txtID.pActiveSheet.Range("E1").Select
        'txtStID.Selection.Copy
        'txtID.pActiveSheet.Range("B1").Activate
            If pFeatureLayer Is Nothing Then
                MsgBox "It Is Empty"
                Exit Sub
            End If
        Set pFeatureSelection = pFeatureLayer
            pID = "[ID] IN (" & txtID.Text & ")"
      Set pQueryFilter = New QueryFilter
      pQueryFilter.WhereClause = pID
      pActiveView.PartialRefresh esriViewGeoSelection, Nothing, Nothing
              'THE PFEATURESELECTION LINE BELOW DOES NOT WORK. I DON'T KNOW WHY!!
      pFeatureSelection.SelectFeatures pQueryFilter, esriSelectionResultNew, False
        'THIS CODE BELOW SEEMS TO BE AN UPDATED VERSION BUT DOES NOT WORK
        ''pActiveView.PartialRefresh(esriViewDrawPhase.esriViewGeoSelection, Nothing, Nothing)
                ' Perform the selection using the user input.
        '' pFeatureSelection.SelectFeatures(pQueryFilter, esriSelectionResultEnum.esriSelectionResultNew, False)
End Sub
Outcomes
