How do I find if a line intersects a closed line (polygon)?
893
01-24-2014 05:04 AM
Andreas_W_Paulsen
New Contributor III
I have one closed Polyline: "rectangle" and an open Polyline: "line".
Both Polylines may be Z aware.
What is the best way to find if the "line" intersects the "rectangle" in the XY plane?
That is I want a 2D (XY) test for intersection. I do not need the actual coordinates of any intersection(s).
LeoDonahue
Occasional Contributor III
ITopologicalOperator
Andreas_W_Paulsen
New Contributor III
Call the Intersect method with esriGeometry0Dimension?
Does this take care of the 2D part of the intersection or do I have to strip away any z information first by copying the x and y value of the points?
LeoDonahue
From the docs:
If the Geometry includes z or m values, the z or m domains, z or m resolutions,  and z or m cluster tolerance properties must also be defined. The cluster  tolerance and resolutions can be quickly and easily set using SetDefault methods  on ISpatialReferenceResolution and ISpatialReferenceTolerance interfaces.
WeifengHe
If you do not need the actual coordinates of any intersection(s) as you said, you can also use IRelationalOperator methods to test the spatial relation between geometries.
