marcus0202
MapView freezes when leaving Activity (SDK v. 10.2)
Discussion created by marcus0202 on Jan 23, 2014
Latest reply on Mar 14, 2014 by tmsbn90
After updating the SDK to version 10.2 we encounter a new problem which causes the app to freeze. The problem appears from time to time when the user the leaves the Activity which has a MapView in its layout. When I managed to investigate is that the problem is caused when the MapView object is removed from memory. Normally removing of MapView should look like this (logs from LogCat):
 D/ArcGIS.LifeCycle(10955):    MapSurface.destroyContext <start>:GLThread 554
 D/ArcGIS.LifeCycle(10955):    MapSurface.destroyContext <- release WebMapTask>:GLThread 554
 D/ArcGIS.LifeCycle(10955):    MapSurface.destroyContext <- shutdown threadpool>
 D/ArcGIS.LifeCycle(10955):    MapSurface.destroyContext <- pause (release)>
 D/ArcGIS.LifeCycle(10955):    MapSurface released
 D/ArcGIS.LifeCycle(10955):    MapSurface.destroyContext <- recycle layers>
 D/ArcGIS.LifeCycle(10955):    MapSurface.destroyContext <- release map>
 D/ArcGIS.LifeCycle(10955):  < MapSurface.Context recycled. com.esri.android.map.MapSurface{418e66b0 V.E..... ........ 0,0-640,671}
 D/ArcGIS.LifeCycle(10955):    MapSurface.destroyContext <- release done!>
 D/ArcGIS.LifeCycle(10955):    MapSurface.destroyContext <done>
But from time to time it suddenly stops during this process, then the log look like that:
Next no further log is printed until the app notifies about the crash.
Has anyone encountered the same problem or found any solution to it ?
Outcomes
