Numbering unique value -new column
713
01-22-2014 01:07 AM
Dd
hello
first of all - my english is basic 🙂 -sorry
I have a problem:
I want to paste contents from "column1" to "column2" with numbering, but i don't want "copy ID". I would numbering unique value anew.
For example:
Column1: Value in Column: A,B,B,B,C
I want to get: Column2: 1A,1B,2B,1C
Anyone know how to do it  in ARCGIS ?
JimCousins
MVP Regular Contributor
You want to do a sequential calculation. Have a look at:
http://resources.arcgis.com/en/help/main/10.1/index.html#//00170000004s000000
Towards the bottom is "Accumulative and sequential calculations"
Best Regards,
Jim
Dd
Thanks @jimcousins for answer
I don't know how i should do it..i try many times but still don't work (i never used python language)
I used "Calculate the accumulative value of a numeric field."
Script:
Expression:
accumulate( !oznaczen_1! )
Expression Type:
PYTHON_9.3
Code Block:
total = 0
def accumulate(increment):
global total
if total:
  total += increment
else:
  total = increment
return total
Result Error:  ERROR 00539 ... accumulate "E"
Someone could write correct script ?
Column A: source data, for example: A,A,A, B,B,B AB1, AB2
Column B: empty -here i want get value: 1A,2A,3A, 1B,2B,3B, 1AB1 ...
thanks for any help
JimCousins
You have coded the accumulative value of a field, so basically record 1 + record 2 + record 3 + record 4.......
You should be using the calculate sequential ID or number based on an interval.
I see the following steps:
1) get a listing of unique values within the column ( if there are not too many, you could actually enter these into a list in the expression)
2) for each unique value, if the record == the value, run the sequential ID, appending the unique value to it. So if the input column = A, then it runs the code, if not, it goes to the next record, and if it = A, it runs the code.... then it switches to "B" and does the same sequence.
Regards,
Jim
