Creating sublayers to enable split-screen view
1050
01-21-2014 02:19 AM
AnthonySmith3
Hi
This may be obvious, but I can't find a simple way to do this. I added a layer of building outlines, created the models, then cut out two adjacent lots as per the guidance notes in the Philadelphia example. I then pasted these back in, created a new building and generated models. Everything works fine, except when uploaded as a web scene they exist as separate layers. To enable split-screen, slidebar etc it looks like you have to have the as-built and redevelopment models added as sublayers to the building layer.
Does anyone know how I can do this? It's simple enough to create a layer, but not a sublayer, nor to assign a layer as a sublayer to an existing layer.
Tags (3)
OlaSvensson
I might be misunderstanding what you mean, but if  you want to prepare to layers for comparative view in a 3D-scene (aka "Swipe view"), then all you need to do is give them the same Group Name in the export settings (see the section "Layer Group" here).
AnthonySmith3
aha thanks, knew it would something simple
