Solved! Go to Solution.
Hi Ganesh,
Are you specifically using the 'Basic Viewer' template?
If you are, are you using a webmap?
If so, you may want to look into modifying the init() function in App.js and the createMap() function in layout.js
*edit.
I noticed that a lot of threads you have made are still marked as 'unanswered.'
Some of those threads also have responses, or ask questions of you, but you did not respond.
Make sure you go back and close threads that no longer have a use!
This will encourage others to do the same (as well as encourage people to answer your future questions!)
Thanks Ganesh!
Hi Ganesh,
*edit.
Thanks Ganesh!
Hi John
I found the answer on my own. I created a function in layout.js that programmatically allows to add Navigation tools and custom tools.
Thank you for help. And, also you suggested to mark answered to some of the threads, I have done for some of them, but not for all, the reason is I haven't got that thread working even with comments from gis folks. I will revisit the thread to make them answered.
Thank you for your support.
