var legendLayer = []; map.on("layer-add-result", function (evt) { legendLayer.push({ layer: Layer1, title: 'AAABBC' }); var legendDijit = new Legend({ map: map, layerInfos: legendLayer }, "legendDiv"); legendDijit.startup(); }); map.addLayer(Layer1);
map.on("layers-add-result", function (evt) { var layerInfo = arrayUtils.map(evt.layers, function (layer, index) { return { layer: layer.layer, title: layer.layer.name }; }); if (layerInfo.length > 0) { var legendDijit = new Legend({ map: map, layerInfos: layerInfo }, "legendDiv"); legendDijit.startup(); } }); map.addLayers([Layer1, Layer2]);
Solved! Go to Solution.
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" /> <title></title> <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } #map { padding: 0; } </style> <script src="http://js.arcgis.com/3.8/"></script> <script> var map; require([ "esri/map", "esri/dijit/BasemapGallery", "esri/arcgis/utils", "dojo/parser", "esri/layers/ArcGISDynamicMapServiceLayer", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/TitlePane", "dojo/domReady!" ], function ( Map, BasemapGallery, arcgisUtils, parser, ArcGISDynamicMapServiceLayer ) { parser.parse(); map = new Map("map", { basemap: "topo", center: [-105.255, 40.022], zoom: 13 }); //add the basemap gallery, in this case we'll display maps from ArcGIS.com including bing maps var basemapGallery = new BasemapGallery({ showArcGISBasemaps: true, map: map }, "basemapGallery"); basemapGallery.startup(); var dynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Population_World/MapServer", { "opacity": 0.5 }); map.addLayer(dynamicMapServiceLayer); map.on("layer-add-result", function (evt) { console.log("Layer add result event fired - " + evt.layer.id); }); map.on("layers-add-result", console.log("Layers add result event fired")) basemapGallery.on("error", function (msg) { console.log("basemap gallery error: ", msg); }); }); </script> </head> <body class="claro"> <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="width:100%;height:100%;margin:0;"> <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'" style="padding:0;"> <div style="position:absolute; right:20px; top:10px; z-Index:999;"> <div data-dojo-type="dijit/TitlePane" data-dojo-props="title:'Switch Basemap', closable:false, open:false"> <div data-dojo-type="dijit/layout/ContentPane" style="width:380px; height:280px; overflow:auto;"> <div id="basemapGallery"></div> </div> </div> </div> </div> </div> </body> </html>
map.addLayers(dynamicMapServiceLayer);
map.addLayers([Layer1]);
