AnsweredAssumed Answered
Multiple service areas
Question asked by matthew.f.tenold on Jan 13, 2014
Latest reply on Jan 13, 2014 by JGravois-esristaff
Hi everyone,
I new to using the ESRI JS API, and I have a hard time working with arrays and the ESRI ServiceAreaTask.   What I would like to do is allow a user to place multiple points and see a 1 and 2 minute response area around each point.
Here is my code
I keep getting the following warning with Firebug: "Graphic is not defined"  I am confused since I am defining Graphic as new.
Any help would be greatly appreciated.
function mapClickHandler(evt){
      map.graphics.clear(); //clear existing graphics
      //define the symbology used to display the results and input point
      var pointSymbol = new esri.symbol.SimpleMarkerSymbol(
        esri.symbol.SimpleMarkerSymbol.STYLE_DIAMOND,
        20,
        new esri.symbol.SimpleLineSymbol(
          esri.symbol.SimpleLineSymbol.STYLE_SOLID,
          new dojo.Color([88,116,152]),
        new dojo.Color([88,116,152,0.45])
   //map.graphics.add(new esri.Graphic(evt.mapPoint, pointSymbol)).getDojoShape().moveToBack();
   //alert(evt.mapPoint.toString());
   var geometry = new esri.geometry.Point(evt.mapPoint.x,evt.mapPoint.y,map.spatialReference);
   var graphic = new Graphic(geometry);
   var inPoint = new array();
   for (var i = 1; i < evt.geometry.length; i++) {
      inPoint.push();
   //alert(evt.inPoint.toString());
      //var inPoint = new esri.geometry.Point(evt.mapPoint.x,evt.mapPoint.y,map.spatialReference);
      //var location = new esri.Graphic(inPoint,pointSymbol);
      //map.graphics.add(location);
      var features = [];
      features.push(location);
      var facilities = new esri.tasks.FeatureSet();
      facilities.features = features;
      params.facilities = facilities;
      //solve
      serviceAreaTask.solve(params, function(serviceAreaSolveResult){
        var serviceAreaSymbol = new esri.symbol.SimpleFillSymbol(
          esri.symbol.SimpleFillSymbol.STYLE_SOLID,
            new dojo.Color([232,104,80]),
          new dojo.Color([232,104,80,0.25])
        dojo.forEach(serviceAreaSolveResult.serviceAreaPolygons,function(serviceArea){
          serviceArea.setSymbol(serviceAreaSymbol);
          map.graphics.add(serviceArea);
      }, function(err){
        console.log(err.message);
Outcomes
