tatadista
esri map layer not loading in android
Discussion created by tatadista on Jan 12, 2014
Latest reply on Jan 14, 2014 by JUihlein-esristaff
Hi all,
I am using the below html file to load the layer in iphone and android phone, but in iphone it is working fine and in android it is not at all laoding.
[HTML]<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
    <meta http-equiv="X-UA-Compatible" content="IE=7" />
    <title>Create Map with Custom ArcGISDynamicMapServiceLayer Layer Definitions</title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/1.6/js/dojo/dijit/themes/tundra/tundra.css">
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=1.6"></script>
    <script type="text/javascript">
      dojo.require("esri.map");
      var plotnumber, sectorname;
      function init() {
    //alert(plotnumber + ' - ' + sectorname);
    queryTask = new esri.tasks.QueryTask("http://gis.adm.gov.ae/sddgisms/rest/services/MyLand_ZoneSectorPlot/MapServer/0");
    //dojo.connect(queryTask, "onComplete", showResults);
                plotnumber = '1' ;  sectorname = 'Lulu Island';
    //build query filter
    query = new esri.tasks.Query();
    query.returnGeometry = true;
    query.outFields = ["SQMI"];
    //query.where = "PLOTNUMBER='1' AND SECTORTPSSNUMBER ='Lulu Island' ";
    query.where = "PLOTNUMBER='"+plotnumber+"' and SECTORTPSSNUMBER ='"+sectorname+"'";
    //execute query
    queryTask.execute(query, showResults);
    //showResults() ;
      function showResults(results) {
        var extent = results.features[0].geometry.getExtent();  alert(JSON.stringify(extent));
        //  map = new esri.Map("map",{extent: extent });
       // var startExtent = new esri.geometry.Extent(148297.8, 2581597.8, 317702.2, 2766402.2, new esri.SpatialReference({wkid:32640}) );
        var map = new esri.Map("map", {extent:extent});
        var tiledMapServiceLayer = new esri.layers.ArcGISTiledMapServiceLayer("http://gis.adm.gov.ae/sddgisms/rest/services/Images/ortho_2012_adm_t/MapServer");
        map.addLayer(tiledMapServiceLayer);
        //Use the ImageParameters to set map service layer definitions and map service visible layers before adding to the client map.
        var imageParameters = new esri.layers.ImageParameters();
        //layer.setLayerDefinitions takes an array.  The index of the array corresponds to the layer id.
        //In the sample below I add an element in the array at 3,4, and 5.
        //Those array elements correspond to the layer id within the remote ArcGISDynamicMapServiceLayer
        var layerDefs = [];
         layerDefs[0] =  "PLOTNUMBER='1'";
        imageParameters.layerDefinitions = layerDefs;
        //I want layers 5,4, and 3 to be visible
         imageParameters.layerIds = [2,1,0];
          imageParameters.layerOption = esri.layers.ImageParameters.LAYER_OPTION_SHOW;
          imageParameters.transparent = true;
        //construct ArcGISDynamicMapServiceLayer with imageParameters from above
        var dynamicMapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://gis.adm.gov.ae/sddgisms/rest/services/MyLand_ZoneSectorPlot/MapServer", {"imageParameters":imageParameters});
        map.addLayer(dynamicMapServiceLayer);
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="tundra">
    <div id="map" style="width:900px; height:600px; border:1px solid #000;"></div>
  </body>
</html>[/HTML]
Please suggest any solution for this....
Do i need to use any mobile based javascript api or this is enough or what else i need to change....
Outcomes
