Are you sure those are the correct coordinates for the line? If you change the first coordinate, you'll see the line off the coast of Africa.
var polylineJson2 = { "paths":[[[2013940.01178484457,1736610.08635829584],...
Also, can you get in the habit of putting your code within the CODE tags? It makes it much easier to read.
