keags1
Exporting JPW or GeoTiff - VB.Net
Discussion created by keags1 on Jan 8, 2014
Latest reply on Jan 16, 2014 by keags1
I am not sure if this is the correct location for this query, but here it is.
I am trying to export data from the data view in ArcMap to a georeferenced JPG or Tiff.
I can do it manually, however I would like to automate the process to export based upon a polygon layer.
I have been able to get the code working, however, the coordinates of the exported raster (Tiff) have not been preserved.
Could someone please point me in a direction of some documentation of how best to do this?
Please find my code below:
I know its a little rough, its a work in progress I have found some examples online have have spliced things together as I see it could work.
Private Sub Button1_Click(sender As System.Object, e As System.EventArgs) Handles Button1.Click
        Dim pEFeat As IEnumFeature
        Dim papp As IApplication
        Dim pmxdoc As IMxDocument
        Dim pmap As IMap
        Dim pFLayer As IFeatureLayer
        Dim pFClass As IFeatureClass
        papp = My.ArcMap.Application
        pmxdoc = papp.Document
        pmap = pmxdoc.FocusMap
        pFLayer = pmxdoc.SelectedItem
        pFClass = pFLayer.FeatureClass
        Dim pFCursor As IFeatureCursor
        pFCursor = pFLayer.Search(Nothing, False)
        Dim pFeature As IFeature
        pFeature = pFCursor.NextFeature
        Do While Not pFeature Is Nothing
            Dim MapSheet As String
            Dim BatchField As String
            Dim pfd As IFeatureLayerDefinition
            Dim pActiveView As IActiveView
            Dim pExporter As IExporter
            Dim pEnv As IEnvelope
            Dim exportFrame As tagRECT
            Dim pWorldFile As IWorldFileSettings
            Dim hdc As Long
            Dim pqfilter As IQueryFilter
            pfd = pmxdoc.SelectedLayer
            BatchField = "TAG"
            MapSheet = pFeature.Value(pFeature.Fields.FindField("TAG")) 'pFLayer.value(pFLayer.fields.findfield("MAPSHEET"))
            pfd.DefinitionExpression = BatchField & " = '" & MapSheet & "'"
            pqfilter = New QueryFilter
            pqfilter.WhereClause = BatchField & " = '" & MapSheet & "'"
            ' pFCursor = pFClass.Search(pqfilter, False)
            pmxdoc.ActiveView.Extent = pFeature.Shape.Envelope
            pmxdoc.FocusMap.MapScale = 30000
            pmxdoc.ActiveView.Refresh()
            'Export the view
            pActiveView = pmxdoc.ActiveView
            pExporter = New TiffExporter
            pEnv = New Envelope
            Dim BEnv As IEnvelope
            BEnv = pmxdoc.ActiveView.Extent
            'Setup the exporter
            exportFrame = pActiveView.ExportFrame
            'pEnv.PutCoords(exportFrame.left, exportFrame.top, exportFrame.right, exportFrame.bottom) <--- Here the coords read 0 , 0 , 940 , 940 (not correct)
            pEnv.PutCoords(BEnv.XMin, BEnv.YMin, BEnv.XMax, BEnv.YMax) ' If I use this, I get a "NOT ENOUGH MEMORY ERROR" but the coordinates are correct
            Dim outloc As String = "C:\temp\"
            Dim out_prefix As String = "MapNumber"
            Dim dpi1 As Integer
            dpi1 = 800
            With pExporter
                .PixelBounds = pEnv
                .ExportFileName = outloc & "\" & MapSheet & out_prefix & ".tif"
                .Resolution = dpi1
            End With
            'Recalc the export frame to handle the increased number of pixels
            pEnv = pExporter.PixelBounds
            pWorldFile = pExporter
            pWorldFile.MapExtent = pEnv
            pWorldFile.OutputWorldFile = True
            hdc = pExporter.StartExporting
            pActiveView.Output(hdc, dpi1, exportFrame, Nothing, Nothing)
            pExporter.FinishExporting()
            pFeature = pFCursor.NextFeature ' pFCursor.NextFeature
        Loop
    End Sub
Regards,
K
Outcomes
