thomas_payne
Topographic errors when making route event layers within an SDE environment
Discussion created by thomas_payne on Jan 7, 2014
Latest reply on Jan 10, 2014 by MLF
Hi there
Any help on the below porblem greatly appreciated:
I have a route and route event tables - and if I make a route event layer within a normal mxd enviroment all is fine.
This route layer is then added to an SDE. When I then generate a route event layer using the route from the SDE, some of the event locations are slightly off. It is although a different measurement technique is being used (2D v 3D)
Any info on this problem would be a huge help!
Outcomes
