merebears
Adding Buffer Distance Variable to Model
Discussion created by merebears on Jan 7, 2014
Latest reply on Jan 7, 2014 by merebears
I am creating a model that uses the buffer tool and I wanted to create a variable for the buffer distance so that you can just open the tool and plug in your distance without having to go in to edit the model.  Right now I have inserted a variable and set it to double.  It is also set as a parameter but it in no way is connected to the buffer tool in the model.  Is there a way to do this?
Outcomes
