Having a little problem casting a byte array field ( as defined in shapefile database ) to and igeometry object.
Code example ->
Dim iGeo As IGeometry
iPoly = TryCast(ds.Tables(0).Rows(x).Item("shape"), IGeometry)
But it fails with ->
Unable to cast object of type 'System.Byte[]' to type 'ESRI.ArcGIS.Geometry.IGeometry'.
using vb.net ... Any Ideas
