br8kwall
Feature Access service: 00166: Layer's ObjectID is not maintained by the database
Discussion created by br8kwall on Jan 2, 2014
Latest reply on Jan 2, 2014 by br8kwall
Using 10.2 Arcmap/ArcGIS Server on Windows with PostgreSQL 9.2/PostGIS 2.0. I'm try to publish a Feature Access service with all the Operations and Capabilities enabled against a purely PostGIS table (not using Esri's ST_GEOMETRY type). However, when publishing I get this blocking error during the ArcMap validation part.
"00166: Layer's ObjectID is not maintained by the database and the feature service is being published with Create capability enabled"
Here is the database creation script, which clearly has an auto-incrementing primary key (and editing the data outside of ArcMap proves the database is managing the ObjectID values)
CREATE SEQUENCE test_schema.mypoint_const_b_seq
INCREMENT 1
MINVALUE 1
MAXVALUE 9223372036854775807
 START 1
CACHE 1;
 ALTER TABLE test_schema.mypoint_const_b_seq
 OWNER TO postgres;
CREATE TABLE test_schema.mypoint_const_b
  objectid integer NOT NULL DEFAULT nextval('test_schema.mypoint_const_b_seq'::regclass),
  volmon24_i integer,
  site_id integer,
  waterbody character varying(30),
  CONSTRAINT mypoint_const_b_pkey PRIMARY KEY (objectid)
WITH (
  OIDS=FALSE
SELECT AddGeometryColumn ('test_schema','mypoint_const_b','geom',4326,'MULTIPOINT',2,     false);
  OWNER TO postgres;
CREATE INDEX mypoint_const_b_geom_gist
  ON test_schema.mypoint_const_b
  USING gist
  (geom);
What are the rules for creating PostGIS tables that ArcGIS Server 10.2 can use for publishing a Feature Access service with the Create function enabled?
Outcomes
