Solved! Go to Solution.
The Story Map Tour app template doesn't support popups. It's something we might add in future but we wanted to keep the user experience of the Map Tour really simple and streamlined.
There's an entry in Esri Ideas site for popups in map tours if you'd like to vote up that enhancement:
ArcGIS Idea - popup in Map Tour
If you want to give people a tour-like experience but with full support for popups, you could use the Story Map Journal. Using Story Map Journal gives you a lot more flexibility than Story Map Tour: you can zoom in on the map as people go through your tour, switch to a different maps, use clickable main stage actions in the section text to open up popups on your map or change extent, etc, etc. For example, check out this example:
http://storymaps.esri.com/stories/2014/brazil-beyond-the-stadiums/
Rupert
Rupert
