Howdy all,I need help getting the sidebar to collapse on my map. I know the rest of the code needs some work. I am having issues adding the sidebar collapse code. The ideal web map would be one where someone could search for a name, click on results to get zoom to the plot, and a sidebar that would hold the legend. I have a working version that does not have a sidebar but I believe a legend would be nice for my users.The real issue is this section
var leftDiv = dijit.byId("leftDiv");
//connect the click event for the sidebarCollapseDiv
dojo.on(sidebarCollapseDiv, 'click', function(evt) {
if (leftDiv.domNode.style.display === "none") {
dojo.domStyle.set(leftDiv.domNode, 'display', 'block');
dojo.domClass.remove(sidebarCollapseDiv, 'open');
dojo.domClass.add(sidebarCollapseDiv, 'close');
} else {
dojo.domStyle.set(leftDiv.domNode, 'display', 'none');
dojo.domClass.remove(sidebarCollapseDiv, 'close');
dojo.domClass.add(sidebarCollapseDiv, 'open');
leftDiv.resize();
//resize the map div
dijit.byId('mainDiv').resize();
if (map) {
map.resize(true);
map.reposition();
dojo.domStyle.set(sidebarCollapseDiv, 'display', 'block');
Below has my full code. Thank you in advance!
