Unable to load many images into raster mosaic
935
9
12-23-2013 03:51 AM
RobertBuckley
New Contributor III
I have 1300 aerial images which I would like to combine into one single image. I have created a geodatabase raster in ArcGIS 10.0 and load the images into the raster. I have never been able to complete this task due to memory errors. The last time I tried the error message was in a window titled "ArcGIS Indexing window" and the message "System.OutOfMemoryException".
ArcGIS Advanced is installed on windows 7 with 4GB Ram.
Could anyone tell me how to get around this problem?
Yours,
RB
808707
New Contributor III
I'm no expert but have you got it set up for 64bit processing? It sounds like you're running out of memory.
Can you trying it with fewer tiles and see if it works? Maybe start with 20 and work up from there.
RobertBuckley
New Contributor III
Thanks for the reply....It worked with 5 images...then I loaded about another 50 and left it overnight. In the morning I was greeted with the same old error! and 64bit Processing set-up? what´s that...and how do I do it?
MichaelVolz
Esteemed Contributor
Have you tried using a Raster Mosaic Dataset?
RobertBuckley
New Contributor III
Yes...basically the same problem. But I can´t use the Mosaic Dataset because I have to make the raster image available to 9.3 users as well. I think there will be a compatibility issue.
MichaelVolz
Do you have any control over whether these users can be brought up to a more current version of ArcGIS than 9.3?
RobertBuckley
New Contributor III
No...they are external groups.
GeospatialTechnology
Here..
http://blogs.esri.com/esri/arcgis/2012/10/31/announcing-64-bit-geoprocessing/
Ah you're using 10.0. I think you've ran into the limits of 32 bit processing.
New Contributor III
Also read the performance considerations paragraph at the bottom of this webpage
http://resources.arcgis.com/en/help/main/10.1/index.html#//00210000003q000000
JakeSkinner
Esri Esteemed Contributor
Do you have ArcGIS Server with Image Extension?  The Image Extension allows you to publish mosaic datasets to ArcGIS Server as either a map or image service.  ArcGIS Desktop 9.3 will be able to consume these 10.0 services.
If you do not have ArcGIS Server with this extension, can you provide some more details?
1.  What type of rasters are you trying to mosaic (i.e. SIDs, TIFFs, etc)?
2.  What type of geodatabase are you trying to mosaic these rasters to (i.e. File, Personal, SDE)?
