I'm using the arcpy.Contour tool to create a polyline featureclass of contours based on a raster surface. It works great, but the polylines are not z-enabled. In ArcMap, they look great, but when I pull them into ArcScene, they all show up at the same elevation.
Any ideas? I'm using a z-factor of 1 in my Contour tool.
Jon, I think this is a 2 stage process. Make the contours then use 3d analyst / 3d features / Feature to 3d by attribute. The Z value will be "Contour". Then you will have a true polylineZ. Cheers, Neil
