Export Collada from CityEngine
2669
5
12-20-2013 11:54 AM
DaniloD
Hi, I have a problem to export a file "collada" from CityEngine.
I select the Shape, export them as collada but when I load it in Sketchup does not appear any element!
Only when I export a KMZ file appears ONLY on google hearth
I apologize for my bad english
greetings
MatthiasBuehler1
Are you working with georeferenced data ?
Can you try just a simple cube first, before exporting complex data ? Does it work then ?
Let me know..
m.
SheebaSbeen
Dear matthiasbuehler
I have the same issue, but if i select one model that's easily exporting in .gdb format and import in arc scene but when i select the whole data set and try to save in collada, this doesn't work. the out put is images of models 😞
and yes i am working on georef data set.
MatthiasBuehler1
I'm not sure I understand what you mean..
You export some models to .dae, but when loading in SketchUp, you don't see it ?
Let me know ..
m.
SheebaSbeen
Yes i export models to .dae. but when i try to add it in arcscene, its only shows images. or if i try to open using City engine tools. again this tool does not read .dae files.
You can see the attachment.
Regards.
MatthiasBuehler1
Are you trying to import .dae files with the 'Features from CE rules' GP Tool ?
Did I understand you correctly ?
Let me know ..
matt
