FDO Error? works on 1 computer but not the other
5993
12-20-2013 11:11 AM
MikeHenson
I am having an issue with labels in a map. On one computer, my labels work great, and if I call up the same mdx map on another computer, I am getting the following error
One or more layers failed to draw:
FDO error: 0 [Failed to label layer All Manholes for class Default.]
A column was specified that does not exist.
Can anybody help me with what might be happening here? Thanks
NidhinKarthikeyan
Occasional Contributor III
Label Expression can cause this issue. Remove the expression and check how it works. Also you can recreate the mxd in the problematic machine.
MikeHenson
thanks for the reply. I understand the labels could be causing this. Whats odd is that it works on 2 of 3 computers. I can't understand why it won't work on the one.  One of the working computers is using 10.1, and the other is using 10.2, so it cant be a version problem either.  I am just really perplexed! 🙂
