Hi all,
I am installing the Citizen sample for 10.2 and testing it,
http://resources.arcgis.com/en/help/localgovernment/10.2/index.html#/What_is_Citizen_Service_Request...
When I run the application it shows an error message when it tries to access the feature
http://<myserver>:6080/arcgis/rest/services/Citizens/ServiceRequest/FeatureServer/0
Error message:
Error: Error handling service request : Server object extension 'featureserver' not found.
Code: 500
I think this error would most likely be caused by you simply not having a proper SDE Database registered with your ArcGIS for Server. Would you double check your validations for the Database containing the data for the Feature Server please? Thank you-
Justin
How do I register my "SDE Database with ArcGIS for Server" ?
