grjakel
Print subtypes
Discussion created by grjakel on Dec 19, 2013
Latest reply on Dec 20, 2013 by achapkowski-esristaff
I'm trying to use this script to list subtypes in  a database
for stcode, stdict in subtypes.iteritems():
    print('Code: {0}'.format(stcode))
    for stkey in stdict.iterkeys():
        if stkey == 'FieldValues':
            print('Fields:')
            fields = stdict[stkey]
            for field, fieldvals in fields.iteritems():
                print(' --Field name: {0}'.format(field))
                print(' --Field default value: {0}'.format(fieldvals[0]))
                if not fieldvals[1] is None:
                    print(' --Domain name: {0}'.format(fieldvals[1].name))
        else:
            print('{0}: {1}'.format(stkey, stdict[stkey]))
I keep getting the following error
Runtime error
  File "<string>", line 1, in <module>
NameError: name 'subtypes' is not defined
I'm trying to add the path to my dataset into line 1 (in the parenthesis)
Any suggestions would be appreciated.
Outcomes
