BTLeslie
Domains and the Field Calculator
Discussion created by BTLeslie on Dec 19, 2013
Latest reply on Oct 9, 2018 by kmsagis
What's the best way to update multiple rows in a database when using domains.  Is there any way of selecting values from a list in the field calculator when using coded values?
One of the advantages of using domains is that I no longer have to look up code meanings because I can select the value from a dropdown list - however if I want to update several rows using the field calculator I seem to have to use the code, which means I have to look it up, which makes this domain a little pointless.... doesn't it?  I must be missing something.
Also.... is there a way of sorting the values in the dropdown list so they appear alphabetically?  I also notice that if I change one of the domain values it jumps to the bottom of the list - is there any way to fix this?
Outcomes
