Ok, the autocollection can be done at a later time, I wondered how it would work since the feature services can't work with rasters.
I have a bit to do before I get to publishing it too. I am starting from absolute zero. Really I need a tutorial from very beginning to publication.
First I build a .GDB and it needs to be an ArcSDE geodatabase? Can a File .GDB be turned into an ArcSDE one?
Then I build the featureclass with subtypes and domains, this will be what is edited. The user will place a point on a basemap and then fill in the table. Then it will update to my gdb and I can run the attribute assistant?
