pierre.weisse
harmonization of spatial references for my data.
Discussion created by pierre.weisse on Dec 17, 2013
Latest reply on Dec 18, 2013 by pierre.weisse
Currently I work in the harmonization of spatial references for my data.
I work with ArcSDE .
I found a script provided by the ESRI Resource Center , allowing me to list all spatial references for the feature classes.
import arcpy
from arcpy import env
# Set the workspace environment
env.workspace = r'Connexions databases \ srv- arcsde.recif.nc @ sde.sde '
# Get a list of the feature classes in the input folder
fcs = arcpy.ListFeatureClasses ()
# Loop through the list
for fc in fcs :
    # Create the spatial reference object
    sr = arcpy.Describe ( fc ) . SpatialReference
    # If the spatial reference is unknown
    if sr.name == " Unknown " :
        print fc + "has an unknown spatial reference \ n"
    # Otherwise , print out the feature class name and
    # Spatial reference
    else:
        print fc + " :" + sr.name + "\ n"
However I need to have a script to compile the same result for games feature classes.
Looking for a script allowing me to achieve a similar result for raster and a second script for the DataSet.
Thank you for your help
Outcomes
