kumdo2004
HEC-GeoRAS Floodplain Delineation error (cross sections updated in HEC-RAS)
Discussion created by kumdo2004 on Dec 17, 2013
Latest reply on Jul 24, 2020 by egj_3028
Hi Folks,
I am using ArcGIS 10.1 and HEC-GeoRas 10.1 I am able to create a GIS project, export all data to HEC-RAS. The first issue was that cross sections GeoRAS created were not in good quality so I updated them by measured bathymetry data. That is, replace the values of station & elevation in Geometric data window in HecRas by the bathymetry data. Subsequently, it is likely to bring up a task of updating the original TIN used to create the original cross sections in GeoRAS to reflect the changes.
Then, I run my steady simulation, and imported back into ArcGIS just fine. I then covert SDF to XML, set up my layer, import the RAS data (coordinations of the updated cross sections matches well with those of the original on GIS) , and do a water surface generation. However, on this last step, the program crashes with the following error:
System.Runtime.InteropServices.COMException(0x80041098):ERROR 010151: No features found in C:\........\Steady_PF\fdtemp.shp. Possible empty feature class.
at ESRI.ArcGIS.GeoAnalyst.RasterConversionOpClass.RasterDataToPolygonFeatureData(IGeoDataset dataset, IWorkspace pWorkspace, String name, Boolean weeding)
at HECGeoRAS.clsMFloodGRIDIntersection.GridToPolygon1(IRaster pRaster, IGeoDataset pGeoIn, IWorkspace pWS, String sName, Boolean sWeeding)
My guess about the causes of this error are:
1) As mentioned earlier, I updated the GeoRas-created cross sections in HEC-RAS so GeoRAS might have a conflict on matching the original cross sections with the updated ones. Any solutions? How can I edit TIN to incorporate this change?
2) GeoRAS uses a unit of meter and HecRAS uses feet. Does this somehow affect floodplain delineation?
Any suggestions, especially detailed ones, would be greatly appreciated.
Dongha
Outcomes
