How To Keep Tool Dialog Box Open
4540
9
12-12-2013 07:17 AM
JonathanMulder
New Contributor III
Yesterday, I checked a checkbox that would automatically close the dialog box for a geoprocessing tool.
But now I want to keep the dialog box open so I can look at the results and Python code.  Any tool I run now just automatically closes the dialog box.
QUESTION: How can I reset my preferences so that the dialog box remains open?
Jon Mulder
DanLee
by Esri Regular Contributor
I see, you meant the checkbox on tool processing dialog:  Close this dialog when completed successfully. Once you checked it, it stays that way until you have a chance to uncheck it. If your process is very fast you may not have time to do that. Try a process that may run longer than 5 seconds (e.g use a larger dataset). When it's running, uncheck that box (on the left side just above the processing message area).
Hope that helps.  🙂
DanLee
By default, the Background Processing is enabled. You can go to Geoprocessing - Geoprocessing options... - uncheck the Enable box under Background Geoprocessing. The tool dialog should stay now.
Does that work?
JonathanMulder
New Contributor III
Thanks, but that doesn't work.  I've checked and unchecked the "Background Processing" checkbox.  Although I can't replicate the step I took, I think it was that when the tool finished processing in Foreground, the dialog box shows the messages printed out during the process, and a button in the upper right said something like "Close the Dialog box".  Also, somewhere on the dialog box, there was a checkbox (I think) that said "Always close dialog box when tool is finished".  That is the checkbox that I enabled and the dialog box ALWAYS closes now.
I guess an ultimate solution is to uninstall ArcMap and re-install so that all the defaults are back to normal...
Jon Mulder
DanLee
Hope that helps.  🙂
JenniferKennedy
Is this still applicable in the software today?  Run a longer process so you have time to uncheck that box?
DanLee
Yes, I have confirmed that it's still the way in ArcMap and probably won't change unless there is a strong request. Sorry about the inconvenience.
JenniferKennedy
Okay, thanks for the confirmation!
JonathanMulder
New Contributor III
Dan,
I ran a long script and I was able to uncheck the checkbox.  Thanks!
Jon Mulder
DanLee
Glad to hear that. You are welcome!
JenniferKennedy
Is this still true?  Is the only way to reset this setting to run a tool that takes a longer time to process, so you have time to uncheck that box on the running tool?
