mrytilahti
Different Composite Locator Results in Geocode Service vs. ArcMap
Discussion created by mrytilahti on Dec 11, 2013
Latest reply on Dec 11, 2013 by timw1984dev
I have a composite locator that was created from building points (US Single House Addresses) and streets (US Dual Range Addresses).
The building point locator appears first in the composite locator because it is inherently more accurate.
When I use the composite locator in ArcMap it correctly lists the addresses from the building points first and the addresses from the streets second when it finds a match.
This is the desired result.
When I publish the composite locator as an ArcGIS service it lists the addresses from the streets first and the addresses from the building points second which is the opposite of what is needed.
This was done using ArcGIS 10.1 SP1 and ArcGIS Server 10.1 SP1 with the data in an SQL Server 2008 R2 geodatabase.
Outcomes
