ajit.nayak87
Writing in to CSV file PROBLEM
Discussion created by ajit.nayak87 on Dec 8, 2013
Latest reply on Dec 11, 2013 by hua17
Dear all,
I have below piece of code and output window . I could not able to write in to CSV file
output:
['date is:7/12/16', 'time is:24-0-0', 'Zenith:104.85', 'Azimuth:110.40', 'Elevation:-14.85', 'Converted Elevation:15.79', '']
date is:7/12/16
time is:24-0-0
Zenith:104.85
Azimuth:110.40
Elevation:-14.85
['date is', '7/12/16\r\ntime is', '24-0-0\r\nZenith', '104.85\r\nAzimuth', '110.40\r\nElevation', '-14.85\r\nConverted Elevation', '15.79\r\n']
code:
import serial
import csv
import string
import os
import time
import sys
def main():
    pass
if __name__ == '__main__':
    main()
    count=0
    f=open("test.csv","w+");
    result = csv.writer(f,delimiter=',', dialect='excel-tab')
    result_statememt=("date","time","Zenith","Azimuth","Elevation","conv_elevation");
    result.writerow(result_statememt)
    f.close()
    while(count<5):
        #time.sleep(60)
        ser=serial.Serial()
        ser.port=2
        ser.baudrate=9600
        ser.open()
        str=ser.read(109)
        print str
        val=str.split(":")
        print val
        print "\n"
        lines=str.split("\r\n")
        print lines
        f=open("test.csv","a+")
        result=csv.writer(f,delimiter=',')
        count=count+1
        #lines=str.split("\r\n")
        #print count
        #f=open("test.txt","a+")
        #result=csv.writer(f,delimiter=',')
        #result.writerow()
        f.close()
    f.close()
    ser.close()
Outcomes
