AnsweredAssumed Answered
Error ORA-28575 with ST_GEOMETRY
Question asked by jjgarcia@sgc.gov.co on Dec 3, 2013
Latest reply on Dec 4, 2013 by jjgarcia@sgc.gov.co
Hi i am configuring the library but when i try to execute the next:
SELECT st_pointfromtext ('point (10.02 20.01)', 0) FROM dual;
i recived this error: ora-28575 unable to open rpc connection to external procedure agent, when i execute:
SELECT st_point(0,0,0) FROM dual;
it works ok with users differents to SDE for example with SYS, but with SDE i have the same error.
i have Oracle 11.2.0.3 64 bits installed on Oracle Enterprise Linux 6 x64.
configuration of extproc:
SET EXTPROC_DLLS=ONLY:/u01/app/oracle/product/11.3.0/db_1/lib/libst_shapelib.so
SET LD_LIBRARY_PATH=/u01/app/oracle/product/11.3.0/db_1/lib
########################configuration of listener:
Test environment
LISTENER_PRT =
  (DESCRIPTION_LIST =
    (DESCRIPTION =
      (ADDRESS = (PROTOCOL = TCP)(HOST = vir11g)(PORT = 1528))
    (DESCRIPTION =
      (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC1528))
SID_LIST_LISTENER_PRT =
  (SID_LIST =
    (SID_DESC =
      (SID_NAME = PLSExtProc)
      (ORACLE_HOME = /u01/app/oracle/product/11.3.0/db_1)
      (PROGRAM = extproc)
Production environment
LISTENER_PROD =
  (DESCRIPTION_LIST =
    (DESCRIPTION =
      (ADDRESS = (PROTOCOL = TCP)(HOST = vir11g)(PORT = 1533))
    (DESCRIPTION =
      (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC1533))
SID_LIST_LISTENER_PROD =
  (SID_LIST =
    (SID_DESC =
      (PROGRAM = extproc)
########################configuration of tnsnames
Test environment
SGCPRT =
  (DESCRIPTION =
    (CONNECT_DATA =
      (SERVER = DEDICATED)
      (SERVICE_NAME = sgcprt)
EXTPROC_CONNECTION_DATA=
(DESCRIPTION =
  (ADDRESS_LIST =
   (ADDRESS = (PROTOCOL = IPC)(Key = EXTPROC1528)
(CONNECT_DATA =
(SID = PLSExtProc)(PRESENTATION = RO)))
SGCPROD =
  (DESCRIPTION =
    (CONNECT_DATA =
      (SERVICE_NAME = sgcprod)
(DESCRIPTION =
  (ADDRESS_LIST =
   (ADDRESS = (PROTOCOL = IPC)(Key = EXTPROC1533)
(CONNECT_DATA =
LISTENER_PRT =
LISTENER_PROD =
######################################Creating library with SDE user:
CREATE OR REPLACE LIBRARY st_shapelib AS '/u01/app/oracle/product/11.3.0/db_1/lib/libst_shapelib.so';
Thanks for your help.
Outcomes
