AnsweredAssumed Answered
Check field before populating field
Question asked by Tonyalmeida on Dec 3, 2013
Latest reply on Dec 4, 2013 by Tonyalmeida
I would like to find a way to have my code check the field (FacltyType) and see if there is any text and if there is skip that feature and continue to check each selected feature and if there is not text in that Field (FacltyType) check the CPUC field in Points_2 for "DWELL" and populate FacltyType with "Single Family Home" if CPUC is "NULL" populate FacltyType with "MobileHome"
Here is my current code.
import arcpy, time arcpy.env.overwriteOutput = True  arcpy.env.workspace = r"C:\Temp\Defult.gdb" fcTarget = 'Points_1' fcJoin = 'Points_2' fcOutput = 'Points_joined'  arcpy.SpatialJoin_analysis(fcTarget, fcJoin, fcOutput, 'JOIN_ONE_TO_ONE', 'KEEP_COMMON')  curR = arcpy.SearchCursor(fcOutput, '', '', '', 'AddressID A') curW = arcpy.UpdateCursor(fcTarget, '', '', '', 'AddressID A')  # init rowW and rowR rowW = curW.next() rowR = curR.next()  while rowR:     currentAddress = rowR.AddressID     print 'current add: ' + currentAddress     while rowW.AddressID != currentAddress:         rowW = curW.next()     if rowR.CPUC == 'DWELL':         rowW.FacltyType = 'Single Family Home'         rowW.APA_CODE = '1110'         rowW.StructType = 'Primary, Private'         rowW.Verified = 'Yes, GRM, TA, ' + time.strftime('%m/%d/%Y')         rowW.Status = 'Active'         rowW.StructCat = 'Residential'     else:         rowW.FacltyType = 'MobileHome'         rowW.APA_CODE = '1150'         rowW.StructType = 'Primary, Private'         rowW.Verified = 'Yes, GRM, TA, ' + time.strftime('%m/%d/%Y')         rowW.Status = 'Active'         rowW.StructCat = 'Residential'         # put any additional conditional field statements here     else:      rowW.FacltyType = rowR.CPUC      # changed the delete statement, targeting the cursor objs (rather than the row objs) if curW:     del curW if curR:     del curR  del rowW, rowR
Outcomes
