Hummingbirds123
wanted: higher than 1 meter resolution base map imagery from 2008/2009 , NM, USA
Discussion created by Hummingbirds123 on Dec 2, 2013
Is it possible to obtain some older imagery? The NAIP imagery I can use is not high enough resolution, I need better resolution..such as sources provided in ESRI online basemap options.
I have a spatial adjustment problem to solve and if I could see high res imagery from 2008 I might be able to find ground control panels that were set for aerial mapping project done that year. The area I would like to see is Villanueva in western San Miguel county, NM, 2008 and/or 2009.
Outcomes
