Update: I think I'm getting closer but still not getting the clips. I've modified my code as follows, but no clipped rasters are generated. I suspect it's in my line comparing extents and the Clip_management function doesn't fire off.Any insight?import arcpy
#from arcpy import env
#from arcpy.sa import*
arcpy.CheckOutExtension("spatial")
# Get name of raster mosaic
in_rastermosaic = arcpy.GetParameterAsText(0)
# Get directories of DOQQ images
in_directories = arcpy.GetParameterAsText(1)
# Get directories of outputted rasters
out_raster = arcpy.GetParameterAsText(2)
TargetRasterExtent = arcpy.Describe(in_rastermosaic).extent
for CurrentDirectory in in_directories:
DOQQRasters = arcpy.ListFiles("*.tif")
for CurrentRaster in DOQQRasters:
DOQQExtent = arcpy.Describe(CurrentRaster).extent
if DOQQExtent.within(TargetRasterExtent.extent):
arcpy.Clip_management(in_rastermosaic,"#","1958_" + CurrentRaster,"#",0,"NONE")
# if arcpy.Describe(CurrentRaster).extent.overlaps(TargetRasterExtent) == 'True':
print "Extent Overlaps"
else:
print "Extent does not Overlaps"
