stefan.haglundesri-se-esridist
Adding rasters located on network to mosaic with Python
Discussion created by stefan.haglundesri-se-esridist Employee on Nov 28, 2013
Latest reply on Nov 28, 2013 by rlwatson
Hello folks!
[EDIT: Never mind:blush:! UNC paths of ocurse!]
I am not able to add rasters to a mosaic dataset from rasters located on a fileshare through python.
If I add rasters using the code from my c: drive, no problem. Using the "Add Rasters..." tool in ArcMap to add rasters on the fileshare also works but for my workflow I need to use Python.
When I use the script to try and add rasters from the fileshare the script runs ok, including reading the path to the raster, but no rasters are added to my mosaic.
I have this (simplified) code:
import arcpy
import os
mdname = r'C:\MyFolder\MyGDB.gdb\MyMos'
rastype = "Raster Dataset"
#This works:
inpath = r'C:\DataFolder\Raster.asc'
#This does not:
#inpath = r'X:\DataFolder\Raster.asc'
updatecs = "UPDATE_CELL_SIZES"
updatebnd = "UPDATE_BOUNDARY"
updateovr = "NO_OVERVIEWS"
maxlevel = "2"
maxcs = "#"
maxdim = "#"
spatialref = "#"
inputdatafilter = "#"
subfolder = "NO_SUBFOLDERS"
duplicate = "EXCLUDE_DUPLICATES"
buildpy = "NO_PYRAMIDS"
calcstats = "NO_STATISTICS"
buildthumb = "NO_THUMBNAILS"
comments = "Add Raster Datasets"
forcesr = "#"
arcpy.AddRastersToMosaicDataset_management(mdname,  rastype, inpath, updatecs, \
                                           updatebnd, updateovr, maxlevel, maxcs, \
                                           maxdim, spatialref, inputdatafilter, \
                                           subfolder, duplicate, buildpy, calcstats, \
                                           buildthumb, comments, forcesr)
My path �??X:\DataFolder\Raster.asc�?� is a connected folder (in both Windows and ArcGIS) that points to \\servername\filearea\DataFolder\Raster.asc
I have also tried connecting through \\MyOrganisation.local\filearea\DataFolder\Raster.asc but with no result.
Has anybody seen a similar problem and can give some pointers?
Thanks!
Outcomes
