Hello Brian -
Can you provide us with some additional information? I'm assuming that you are using ArcGIS for Server 10.2 with the 10.2.0 release of GeoEvent Processor. Are you on a Windows system?
What input connector are you using? Is it one of the out-of-the-box connectors? Have you customized a connector to use an out-of-the-box adapter and transport, or are there components customized using the SDK in play here? Can you describe the source of the event messages you are receiving, what if any filtering or processing is taking place, and describe the output connector you are using to send the event data out from GEP?
- RJ
