Hi Peter,Here is some code that zooms to each point, creates a polygon feature class from the extent, then converts the polygon to a raster in a new directory. The code then copies the original photo to the new directory (overwriting the raster previously created), so that it can use the coordinate information, and then defines the projection of the rasters. If you need to change the size of the raster, you can try adding in the Rescale function.import arcpy
from arcpy import env
from arcpy import mapping
env.overwriteOutput = 1
mxd = mapping.MapDocument(r"C:\temp\python\Points.mxd")
df = mapping.ListDataFrames(mxd)[0]
lyr = arcpy.mapping.ListLayers(mxd)[0]
# Create new photo directory
newPhoto = r"C:\Temp\Python\Photos\New Photos"
dict = {}
# Create dictionary of OBJECTIDs and the path to the photo
with arcpy.da.SearchCursor(lyr, ["OBJECTID", "PHOTO"]) as cursor:
for row in cursor:
rasterName = row[1].split("\\")[-1]
dict[row[0]] = rasterName
firstTime = "True"
# Select each point, zoom/pan to the selected point, create a polygon feature class from extent,
# convert polygon to raster dataset
for key in dict:
if firstTime == 'True':
arcpy.SelectLayerByAttribute_management(lyr, "NEW_SELECTION", "OBJECTID = " + str(key))
df.extent = lyr.getSelectedExtent()
XMAX = df.extent.XMax
XMIN = df.extent.XMin
YMAX = df.extent.YMax
YMIN = df.extent.YMin
pnt1 = arcpy.Point(XMIN, YMIN)
pnt2 = arcpy.Point(XMIN, YMAX)
pnt3 = arcpy.Point(XMAX, YMAX)
pnt4 = arcpy.Point(XMAX, YMIN)
array = arcpy.Array()
array.add(pnt1)
array.add(pnt2)
array.add(pnt3)
array.add(pnt4)
array.add(pnt1)
polygon = arcpy.Polygon(array)
arcpy.CopyFeatures_management(polygon, r"IN_MEMORY\polygon")
arcpy.PolygonToRaster_conversion(r"IN_MEMORY\polygon", "OID", r"IN_MEMORY\raster")
arcpy.CopyRaster_management(r"IN_MEMORY\raster", newPhoto + "\\" + dict[key])
firstTime = "False"
else:
df.panToExtent(lyr.getSelectedExtent())
array.add(pnt1)
array.add(pnt2)
array.add(pnt3)
array.add(pnt4)
array.add(pnt1)
del mxd
# Clear the selection
arcpy.SelectLayerByAttribute_management(lyr, "CLEAR_SELECTION")
list = []
with arcpy.da.SearchCursor(lyr, ["PHOTO"]) as cursor:
for row in cursor:
list.append(row[0])
# Copy original photo to the new photo directory, replacing the raster created previously
for photo in list:
shutil.copy(photo, newPhoto)
spatial_ref = arcpy.Describe(lyr).spatialReference
# Project each raster
env.workspace = newPhoto
for raster in arcpy.ListRasters("*"):
arcpy.DefineProjection_management(raster, spatial_ref)
