AnsweredAssumed Answered
Joining SDE feature class to SDE table fails in 10.2
Question asked by WillAllender on Nov 21, 2013
Latest reply on Nov 25, 2013 by vangelo-esristaff
I originally posted this in Python, but maybe it makes more sense to put it here.  The Python workflow below also does not work if I take each step with ArcToolbox.  Simple workflow:
Grab a feature class and make a Feature Layer
Join a table to the Feature Layer
Is this workflow flawed?
>>> arcpy.MakeFeatureLayer_management(r'Database Connections\GISonGISWT.sde\GIS.V_NM_NIT_BRID_SDO_DT',"BRID_Decodes")
<Result 'BRID_Decodes'>
>>> arcpy.GetCount_management("BRID_Decodes")
<Result '203'>
>>> arcpy.AddJoin_management("BRID_Decodes","IIT_NE_ID",r'Database Connections\GISonGISWT.sde\GIS.XLAR_MV_RIL_BRID_DECODE',"IIT_NE_ID","KEEP_ALL")
<Result '-1'>
That second GetCount should also result with 203 records, not -1.
Other rambling notes:
1) This workflow was built in ArcGIS Desktop 10.0 against a 9.3.1 database and works perfectly there. It fails in Desktop 10.1 with the same 9.3.1 database.
2) This workflow works fine using Desktop 10.2 on a 9.3.1 database.
3) This workflow fails if the database is at ArcGIS 10.2.
4) The join fields are both Long Integer.
5) The database is Oracle 11g on Sun OS.
6) If I move the join table to a file or personal GDB, the workflow works fine, even in 10.2. However, the Esri documentation states that the join table can be an SDE table, and I would prefer to not be copying a bunch of lookup tables to a local file. I need the above workflow to work on dozens of feature classes and tables.
Thanks in advance for any insight you have on this.
Cheers!
Will
Outcomes
