I am currently working on a project where I have to use cost path to determine the least cost path between two points. I have the points as a feature dataset, and have also determined the cost distance and cost back link as well, but when I use the Cost Path tool, it will only show the original two points, instead of creating a path between them. I have even tried converting the feature dataset to a raster for the two points, but the tool still won't work. My professor and I have tried everything we can to think of what could be the problem. Is there any reason that the Cost Path tool would not be creating an actual path between the two points?
