Append Error 000224, but fields are mapped correctly
3092
11-19-2013 03:55 AM
BugPie
Occasional Contributor III
Good morning,
We have run into an issue within a model we have built to update a point file with new projects. We are using a table view to capture new projects. We use the table view as the input to a geocoding tool, we then take the output and "make feature layer" which then gets appended to our sites table. This worked just fine in beta and in production for months now. A few days ago this stopped working in production and we have no idea what the culprit is.  The view is still functioning and the append is still working in beta.
We have a separate model that uses a different table view to capture x,y of differing new sites. We then run this through a plot x,y and "make feature layer" and then append to the same sites table as mentioned above. This works FINE! It seems to be only the output from the geocoding tool and subsequent make feature layer and append that is failing.
The error we receive is 000224. Which if you look at the error all it says is that there are possible mis-matched fields. I have reviewed this model multiple times and the fields are correct, and like I said, it was working fine the other day. I have delete and rebuilt the model, I have rebuilt the geocoding tool as well.
Anyone with a littel insight into other aspects I can review, maybe a way to dig deeper into this error as it's pretty bland as is. Is there a way to more closely monitor the append function to see what the real error is? The sites table we are appending to is on a SQL server 2008 r2 instance. In both prod and beta. Screen shots can be posted if needed.
Thank you.
BugPie
I have some results to share with anyone who has been reading this thread. It turns out, another employee working on the development side had placed a trigger on the site table that had something to do with the append failure. We removed the trigger and success! I'm still working on getting the details. From the surface it seems as though the trigger had some logic where "if x,y are null then". It seems that because some of the records are not geocoded due to bad address they have empty geometry. Not sure how exactly, but this played into the mix here. I will update with any future developments.
BugPie
