I make a QueryTask application. It queries for polygons and return geometry. I let the graphic result show on the map. In FF it works perfectly. But in IE some big polygons not showed. How can I fix this issue. Thanks!
I have similar issue (and posted it but I can't find it now). I have one of the samples from the jsapi 2.0 and put in my map service endpoint polyline dataset. This works fine for one of my endpoints, but then I put in a different more busy and larger polyline and the data doesn't draw completely in FF and stalls IE8 out completely. Thanks.
